Darius »
https://forums.nicoclub.com/darius-u5470.html
Wed Oct 12, 2005 3:24 am
I haven't been able to find a true N1 water pump for under $259 from PH2. There are some on ebay that are "N1" water pumps but are obviously different in every way if you compare the pictures.
Maybe someone can direct me to an N1 oil pump because I've only seen Greddy, HKS, and Tomei from RB Motoring that cost an arm and a leg and I like to jog. (~$1100-1600) Those might be overpriced since they also have the N1 water pump listed at $440 compared to the above price.
Is the OEM water and oil pump that critical to replace with aftermarket brands and higher performance?
