jrc90240sx »
https://forums.nicoclub.com/jrc90240sx-u355.html
Tue Oct 01, 2002 10:39 am
Well just about any engine will want to turn when you give it gas. the engine monts hold it in place keeping it from turning around in a circle. I understand that you most likely know this, your last reply just didnt sound like it. the engine turns in a clock wise motion, causing the motor to lean to the exhaust side of the engine or right side if your looking at it from the front. the transmission will rotate also clock wise, the drive shaft really wont move because it is the rotating axis. the exhaust being connected to the engine will also rotate, makeing it move toward the driver shaft. Any engine will want to rotate, with out the engine mounts it would, if they are warn out they will alow the engine to rotate more then it would normaly. this makes the engine loss some power on take off, or under load. that is why new stiffer engine mounts get you a better 60ft time. hope that clears anything up, and if you already know this sorry for the recap.
Joe
