N1 CRANK
95silvia14
Car: 1995 240SX, 1993 s13 coupe
hey all i just bought a rb25 long block to be built. from what ive read on here it looks like i can put a 26 crank into a 25.
My question is whats the differance between the stock 26 crank and the N1 crank. Also what is the stroke on the 26 crank.
Modified by 95silvia14 at 9:28 PM 2/19/2009
95silvia14
well i figured out the stroke but what are the diffrences between stock crank and the N1 crank
95silvia14
does no one know
250sx se
Car: 240sx w rb25det
i know that putting a 26 crank in a 25 will make it a 26 and i know that the nismo gt500 crank is a 77.7 so with that and by going 1mm bigger on the piston u will be at a displacment of 2771 or better known as a rb28
95silvia14
So do i need to worry about a crank collor or is the oil problem solved on the n1 cranks
baysidebluebnr34
Car: black bnr32, blue r34gtr vspec and r33 gtst circuit car
n1 crank same stroke as standard rb26dett just nitrided and metalaxed.
Cjmartz2k
Car: Hunting for a '89 GTR now
250sx se wrote:i know that putting a 26 crank in a 25 will make it a 26
95silvia14
Hes saying that putting by putting the 26 crank in it will make it a 2.6l
because the only diffrence is that the 26 has a longer stroke but they share the same bore sizes
jdmser
Car: duh
95silvia14 wrote:Hes saying that putting by putting the 26 crank in it will make it a 2.6l
And he's saying because putting a 26 crank in a 25 puts the pistons above deck height. You can't just swap the crank you need the pistons with proper compression height as well. Remember the RB25 is at 9/1 and the RB26 is at 8.5/1.
Carl H
using an rb26 crank in a rb25 block is fine and dandy but unless you want to slam the pistons into the head the moment you go to crank it make sure that you use rb26 specific pistons as well...rods are interchangeable but 26 stuff is always stronger.
95silvia14
thanks for the heads up b4 i did something stupid
250sx se
i forgot u need the pistons my bad. dont they share the same rod lenght
sxracerb25
Car: 1990 Nissan 240sx
250sx se wrote:i forgot u need the pistons my bad. dont they share the same rod lenght
Carl H wrote:rods are interchangeable but 26 stuff is always stronger.
Can you not read?
95silvia14
here is a translation exserpt from the nismo catalog
Vis-a-vis the NISSAN genuine standard crank, it is the long-stroke crankshaft which to the stroke quantity 4mm rise (77.7mm) it could point. The aerodynamic volume displacement of 2,771cc possible note 1) is done by using the NISSAN genuine (1mm oversize) combining with the piston and the NISMO GT connecting rod etc. By the fact that closed die forging + fillet roll processing is adopted for production method, strength is raised. Dynamic balance processing being completed of crank as a single unit. Note 1) When you use on the general public road, remodelling application is necessary.
mcfly
Car: BNR32
There is no N1 crankshaft.
Even the nur spec engines have a 05U crank.
There is the nismo 2.8 though.
95silvia14
I think im going to go with what the nismo catalog says
droppedyota94
Car: 1990 240sx S13 with RB25DET
No N1 crank shaft huh/ http://www.nismoparts.com scroll down just a little and to the left you will see rb26dett click on that then just look around and you will find there is a N1 crank for around $600. better yet here is the exact link to the page.http://www.nismoparts.com/catalog/?section=823
mcfly
Car: BNR32
There is no N1 crank shaft. Call it what you want but thats a 05U part number.?
Be my guest and email them for the part number if you do not believe me, just don't get mad, I am just here to stop the spread of false information.
