Frank_Jaeger wrote:And I mean a helluva lot of problems. In the meantime I will search the board for answers, although given the number of questions I have, I think I'd be better off sticking them in a new thread (as opposed to the sticky.)
BackgroundMy car is a 1989 240sx SE that my mother's boyfriend has lent me. It's automatic... uh... it has an engine and lights and stuff. It has 160k+ miles on it. And that's about all I know. My knowledge on cars is very very minimal. I've had it about a year or two, and I intend on buying it from him.
Wiring / Electronics / Mechanical Problems1. My driver's side window doesn't work. I do believe the motor's fine, as I can here it operating when I press the button to roll it up / down. The window itself does not hold itself up well, and I'm currently using a pen wedged between it and the door to keep it from falling. If I try to roll the window down, sometimes it will catch, and the window will fall down. No go on trying to roll it up, though.
seems to be off track... take off your door panel and have a look at whats going on, use your controls to see if the motor moves.
2. My gas gauge doesn't work. It hasn't ever since Delaware switched to gasohol, or so I've been told. Perhaps it's the wiring, though. Or a bad component.
i highly doubt gas had anything to do with this, its the sensor on the sending unit, wireing, or the gauge cluster...grab an fsm and a multimeter.
3. My trip counter (which is what I rely on since my gas gauge doesn't work) sometimes "sticks", in that it won't count up on some trips. It recently stopped at 66.6 miles (I hadn't been watching it), and when my car wouldn't start after work, I thought the devil was going to come after me. When I try to reset it, it never resets back to 0, but rather to 9, 6, and more recently 5.
need a new trip counter, prob better off looking for another cluster as no one really parts these clusters out unless they are really damaged.
4. My brake light on the dash is always on*.* Except when I accelerate for a while, in which it will flicker off, and then something behind the dash starts buzzing. If I let off the accelerator, the buzzing stops, and the light comes back on. I'm assuming the light is supposed to engage when the ebrake is pulled.
Note that the temp gauge, odometer, speedometer and tachometer all work fine.
brake light generally indicates that the brake fluid is low, or that the ebrake handle is engaged, even slightly it will trigger this light. check fluid, and check wiring, again fsm.
Exterior Problems
1. The paint has worn off the very front of the car (just one piece, I don't know what to call it.) The primer (yellow) is visible, and against the car's red, looks pretty bad.
100% normal for factory paint, respray only.
2. The rear of the car is rusting, underneath the spoiler. I'm worried it will fall off.
it will rust completely around everything that holds the damn spoiler on. remove it now and fix the holes or find a hatch from a spoilerless car.
again, 100% normal with the factory spoiler
Is it plausible that I could remove the offending parts, sand them, find a matching color to repaint them, and refinish them? I will have a spray gun / compressor soon. Has anyone here refinished their entire car themselves? I'm all about DIY. Don't recommend a professional, I won't listen .EDIT: I found this:
http://www.nicoclub.com/articles.php?id=159905[/I]
several writeups on the board on this one, from ghetto to pro.
3. The headlights give off a very murky looking beam. Should the covers be replaced, or can they be cleaned out?
get new bulbs, they are 10 bux a pop at the auto store.
General Concerns1. My engine has a high wine to it, when I approach higher RPM's. It's only done this since I ran the car dry (don't chastise me please, I know I f***ed up). Is this permanent?
dont matter, this engine isnt worth a s*** anyway , start looking for a dohc.
2. The car accelerates rather poorly. The accelerator isn't very responsive at all. ~90% of its' range of motion accelerates the car at a very slow speed. The last ~8% is somewhat decent, and the last ~2% (in which case I have to stomp hard on the accelerator) is too big of a jump from the previous rate. Is there a way to make it more linear?
accel probs, again with the crappy sohc + losing power mated to an auto transmission... prob the worst combo for a fun car.
3. Overdrive seems entirely pointless. When it's not engaged the car doesn't perform reasonably at all. It doesn't shift past 3rd (I think it's 3rd anyway, I never counted), and when it's in 1st and 2nd it takes 4k RPM's to shift, as opposed to 3k RPM's to shift when overdrive is on. (I realize the car doesn't actually shift AT these locations linearly, however they're locations that I'm ABLE to shift at, granted I sustain them long enough.)
find a dohc with 5 speed transmission.
I'm sure there are other questions about the car that I have, but this is all for now. Thanks in advance for any help.
np.
EDIT: Does anyone have a suggested price that they think this car should go for? The tires are pretty horrid (balder than Hunter S Thompson running for Sheriff), although the brake pads and radiator have been replaced. The AC doesn't work well, and the radio / sound system sucks. The dashboard is cracked, the cloth over the seats is tattered, etc. etc. Aside from all of that, it's a decent car. I would just buy a newer car, but I've come to love this one. I'd like to make it respectable.
by the sounds of your vehicle with crappy tires, and engine problem automatic, non working ac cracked dashboard, torn seats, 700 bux?
this car can become respectable, just have to put a lot of money and time into it and stick to your plans. good luck, she needs your money and time.
take it as a blessing... i wouldnt buy this car from him, i would look for a 91+ in good condition if you are looking to spend money on buying one.
Modified by Frank_Jaeger at 8:33 PM 7/28/2009
Modified by Frank_Jaeger at 8:43 PM 7/28/2009
