DjLiquid wrote:with all the other talk about internal wastegates (i know what an external is), bar's (ex: "my turbo can handle 1.7 bar") and 255 cams,
Wastegates are used to control how much boost a turbo makes. When the wastegate opens exhaust gas can flow around the turbo instead of through the turbine. This is how they control how much boost you make. Without a wastegate the turbo wouldn't stop trying to spool and would very quickly destroy itself.An internal wastegate is jsut that, it's built INTO the turbo, the stock T25/T28 etc all have internal wastegates, it's that little "flap" you see next to the turbine on the exhaust side of the turbo. An external one is built into the manifold and again it allows exhaust gases to bypass the turbo.
"Bar" is just a measurement of pressure.1 Bar = 14.5~ psi. bar is the "metric" measurement for pressure.Also on a boost gauge that has psi you'll see "in. Hg" Hg is the elemental sign for mercury, like temperature mercury could be used to measure vacuum, I don't know the sizes of the tubes etc but if you have 30 in. Hg vacuum then that vacuum would have made X amount of mercury in a barometer's tube expand up to the 30 inch mark.
"255 cams" referes to the duration.If you've seen a cam you'll notice it has lobes that stick out. These open the valves so air/gas can get in and exhaust can get out. THe number represents how many degrees of rotation the valve will be open by the cam.So a "255" cam would have the valve "open" for 255 degrees of rotation. (out of the obvious 360 degrees).THis is all jim dandy, however the other important part of the cam is "lift" which is how far it actually OPENS the valve.Longer duration and higher lift will give you more power up top but you'll lose out down low in the rpms, you also won't idle as smoothly etc and you're fuel economy and emissions will suffer.
I hate to bring up hondas but that's what's neat about vtec. they have two lobes of different lift and duration, when you're "on vtec" the rocker arm follows the aggressive cam and opens the valves further and for longer, increasing upper rpm power. When you're not on vtec it uses the more fuel economy/emissions friendly lobe.
