alphapig wrote:I actually kept my stock speakers, and just added a 12 inch Alpine sub. Adding a sub, I think, improves sound quality the most. After that, if you are still not satisfied, you can replace the speakers...
As for the stock radio, you can actually keep it. They apparently use a high-low converter (or something like that) to link up the amp and sub to your stock deck. The sub is then controlled through the stock "bass" tuner.
I chose to keep my stock deck because 1: it matches the car better than any aftermarket one and 2: I didn't want to have to worry about the steering wheel controls messing up.
It's also a lot cheaper!
Goodluck with your sound system, and keep us updated!
Everything you said is true, however IMHO as an audiophile, the stock deck is a POS, especially with the non bose setup! (I have the stock deck in my 07 sedan, and I hate it)
Chamade, for an accurate assessment, I think you'll have to tell us what you're looking for in terms of sound. Also, what type of music do you listen to most. These answers will really determine what you should do.
1st and foremost, I would get rid of the stock stereo. As are most stock decks, its pretty awful. You'll notice that as soon as you replace your stock deck with an aftermarket deck, your sound quality will improve. This is because most good aftermarket decks have a built in amplifier. This allows for richer, clearer sounds, especially at higher vollumes
2nd, if you like bass, then you should get a subwoofer. BUt if you don't like bass, then subs are a waste. I'm a bass guru (Had 2x Rockford Fosgate 12" T1's in my trunk with a custom trunk enclosure and a T1001bd amp pushing them. It literally shook buildings) But now, with my aftermarket stereo and the bose system, it has all the power I need. I'm seriously considering NOT getting a sub. Now I'm not saying that the bose system shakes buildings, I'm just saying the aftermarket deck (Pioneer Avic D3) sounds a hell of a lot better than the stock deck with the same speakers.
Also, as Eric stated, the speakers themselves WILL make a huge difference. Some nice 2 ohm, infinity kappas or reference 6 x 9's and 6.5's will bring the sound out tremendously, even more so if you ditch the factory deck.
Now, the last question of amps, well that's part of the reason that the Bose system sounds better than the stock system (part, not all of the reason) Most people think of amps as powering the woofers, but amps are also used to power the inside speakers as well. (Such is the case of the Bose setups in the Altimas with premium package)
Actually, since you are a true noob to this, if you respond with a price range of where you are trying to stay, what type of music you listen to (rap, rock , pop, country). and whether or not you like bass, I'll get you links on some of the best sounding equipments for a great price giving you the sound that YOU want. Good luck!
