Dealer response: "Set tire pressures and put more miles on it." (no fix but I'm not concerned too much, I consider it tire compound at this point.) I'll put more miles on it.'17MTSsentra wrote: Vibration 1.)
Morningitis: the Bridgestone Turanzas P205/55R16 mounted on the factory steel wheels wake up with flat spots. Extremely noticeable but that goes away within two miles of driving.
Dealer response: "Yeah its transmission its pressure on the slave cylinder and put more miles on it."'17MTSsentra wrote: Vibration 2.)
5th gear whine. I think its 5th, it could be the final drive but its mostly noticeable in 5th and light load.
My Versa only started to whine after 30,000 miles but I don't have any heartburn. Its gears I figure and its likely normal>? Don't hear it over lo radio volume but just curious if anyone has input.
Question 2.)
Is this a normal whine probably>?
Dealer response: "Yeah, we feel it, you got 5yr/60 powertrain warranty and Nissan dealers out west (I am rolling west for 4weeks) If it gets worse stop in and have them look at it. Come on back after your trip and it may loosen up by the time you return." (Welp, I doubt it will fix itself but I can buy into the loosening up theory a bit, I didn't want them to start taking it apart just now anyway.) I guess its ball three and I'll put more miles on it. I'm 100% certain it won't leave me walkin.'17MTSsentra wrote: Vibration 3.)
This one is a deal breaker imo and at this time I'm quite disappointed.
Most prominently about 50mph to 65mph I get a resonating vibration not unlike a driveshaft phasing issue. It reminds me of a 2nd or 3rd order drive-line vibration of some yesteryear rear drive cars and trucks.
The intensity throbs and is most noticeable under loaded 5th gear, or upon part throttle decel at same speeds and becomes non existent when you float near neutral throttle load. Overall it is not violent and not in the wheel or column. It emanates from the floor and seat. It feels like rough road or a very light washboard or wake-up divots but it is resonant.
