Just purchased a replacement Pioneer DEH P6200BT from Crutchfield to replace existing Bose (Clarion) radio receiver and 6 disk player. Disconnected the old units. There are 4 block connections in the back of the old radio factory unit and 1 block connection going to the CD player. I purchased the Nissan Amplifier Interface adapter (OEA-4A). There are only 2 connection blocks (one is rectangle the other in square) provided with the OEA-4A AMP Interface. I connected all the speaker wires from the AMP interface to the Pioneer unit wiring based on provided color coding. All of these connections are on the input side of the OEA-4A harness. I then connected the power wires which are part of the rectangle interface block to the Pioneer unit wiring ( red to red-ignition, yellow to yellow--constant 12 volt, blue to blue/white for remote control CD-R510 control, and black ground. The only wires left that are not used are orange which is a dimmer wire not used, and 2 other wires (black/white and blue/white) which exit the smaller square block connection. I connected the square and rectangle block connections of the OEA-4A AMP interface to the 2 factory block interfaces that match up. The other 2 block connections that were plugged into the factory unit are not used nor is the block connection that attached to the 6 CD player. I also connected the antenna adapter. So I power up the Pathfinder turn on the unit and I see that it's finding stations but I have no sound. I got on the phone with Crutchfield tech, went through the wiring matchup, played with the Amp gain adjustment and still no sound. Tech believes the OEA-4A Amp unit is bad!
I know mkmk and Towncivilian and others have either modifed or replaced there sound systems with some good tips. Am I missing anything?? New OEA-4A AMP inteface will arrive tomorrow. Any help/ideas is appreciated.
