You have to make an assumption on "drive train loss". I commonly see people use ~18-20% for cars with AT's.PopPop wrote:How to convert RWHP and RWTQ to HP and TQ
Those "stupid Greeks" were the ones who gave is most of the words we use today. They are the basis of much of the English language. Those same "stupid Greeks" gave the Western world most of it's culture: science, architecture, drama, mathematics, medicine, politics, philosophy, poetry, literature, military strategy and tactics, and a host of other ideas that raised mankind from primitive life.maxnix wrote:I have never understood the "dyno" slang as the proper word is dynamometer.
Who were those stupid Greeks anyway?
The same also applies to going to the race track also! I'm looking to see similarities in performance based on different MOD'S from Q TO Q. No two tracks are the same and no two drivers are the same so the same applies to the drag strip. U will almost never have the same ET or MPH as the next man in almost the same car. Same driver different track will still yield different results. I can say this before taking any car to a Dyno U had better make sure it's been gone over very well because the Dyno will put a lot of stress on a G50. Not worried about validation. If we all used the same Dyno someone would still come up with someStarPD wrote:Elwesso is entirely correct. Dyno comparisons are valid ony with the same dyno.
And Q45tech is also right. While dyno can provide info for tuning and engine health, it's the actual performance that counts. Doesn't matter if the dyno says you have a lot of HP if the car is slower than others like it in similar condition. Likewise if the dyno says you are low on power, but peroformance is good and 1/4 mile times are average or better, you're still okay. There are differences in dynos and their operators, as well as differeces in traction with the drum depending on tires, ambient temp, air avialbility, and so on.
Best way to use dynoe figures is to get a baseline test, then regularly test as you make changes to the engine. Expensive, but telling if you intend to do much tuning, mods, and/or just maintenance improvements (filters, plugs, injectors, KS, ECU, oil/trans/diff fluid changes, trans cooler, etc).
