deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Fri Dec 02, 2005 2:24 pm
You can lean it as far as 13.5, but I suggest you shoot for 13.2 just because. 14:1 is to lean, your not going to make any extra power just more heat.
Set your base timing to 18 degrees, get some good gas in it and maybe some other octane boost and you may be able to get 19 or 20 degrees base before you start detonating under load.
You should only be able to get 18/19 degrees base with your distributor turned all the way clockwise. This is advancing your entire map, considering you will be using a piggyback that manipulates your maf signal, the ecu will not be reading the map exactly like it should. Generally by leaning your fuel you will be telling the ecu it is getting less airflow than it is, which it turn will be lowering your ecus calculated TP. This will change where it is accessing the ignition map, will be more advance (less TP) at full load compared to a regular ecu so be careful.
