You don't need the engine or the harness. But you will need the front cross member, ECU, left manifold, injectors, etc.evildky wrote:welcome to NICO!I know the market is different when you live on an island but in general it's cheaper to sell the n/a and buy a turbo car, if you would rather swap you'll need the complete engine, harness, ecu and frotn crossmember form a turbo car, the TT swap si possible but very difficult and expensive, satan (thats his user ID here as well as on other boards, search for users and you'll find hime) does make and sell manifolds to run TT's ont he VG30ET
also search a lot, the swap has been detailed and in the link in my sig is my swapped n/a t converted Z31
Thats the best info ive gotten all week along with Az-bums. Ive been thinking i might just keep the N/A and figure out another way to boost my power and torque. Would this be better? or should i stay on the warpath and do the swap??evildky wrote:welcome to NICO!I know the market is different when you live on an island but in general it's cheaper to sell the n/a and buy a turbo car, if you would rather swap you'll need the complete engine, harness, ecu and frotn crossmember form a turbo car, the TT swap si possible but very difficult and expensive, satan (thats his user ID here as well as on other boards, search for users and you'll find hime) does make and sell manifolds to run TT's ont he VG30ET
You won't get a whole lot with an NA. It can be done, but it gets expensive. Turbo swap is the best way to go if you want to stay "stock".Firespirit wrote:
Your help is god-like
I'd bet that finding a complete turbo donor in Hawaii would be much more difficult than haven't a few key components shipped in from the main land.evildky wrote:az is of course correct on the harness and engine statement, but when you are tracking down all the bits and pieces I feel it's just easier to swap the whole engine especially for a beginner
as fro your quest for power, if you have to ask that to me further suggests your best bet is to sellt he n/a and buy a turbo model, if you can not find a turbo, then finding a wrecked donor will likely be cheaper than chasing down all the parts, it also simplifies the swap
as for keeping n/a, you can spend a thousand dollars and add 20 whp to an n/a or spend 1000 on a donor and intercooler and add 100 hp
and V8's are boring
There was a simple list in the link I provided. With the exception of the three things I listed, you need everything in the list on that page. There's stuff you would probably be better off getting new from the dealer and there's some stuff I would swap out while you have the motor out, but the basics are in that link.Firespirit wrote:just a simple list would be nice though im really hoping to start buying parts by the end of the month.
Hey Perrenial just thought i'd check in with you guys again.Im going to be crossing out the N/A conversion to turbo just because right now i need a reliable car and a turbo engine might not be the best choice!So im just gonna work on the the stock vg30 and make it run at it's best. Any Suggestions on what i should start with? Im not looking for power just more handling then anything.Perrenial Badass wrote:There was a simple list in the link I provided. With the exception of the three things I listed, you need everything in the list on that page. There's stuff you would probably be better off getting new from the dealer and there's some stuff I would swap out while you have the motor out, but the basics are in that link.
Quite honestly can't help you any more than that. Post up a WTB ad in the classifieds for turbo swap parts.
Thanks man Looking forward to working on those parts. Also what the heck is that on your avatar! lolPerrenial Badass wrote:Engine-wise, after you do the timing belt and all other maintenance, while staying NA...-headers (zcarparts.com)-"test pipe"-2.5" exhaust (cmperformanceexhaust.com / zcarparts.com)-adjustable cam gears (z31parts.com)
Anything beyond that engine-wise will either result in less reliability, or large amounts of down time. And you probably won't be making too much more horsepower than stock. Suspension wise, get some springs from z31parts.com and some good dampers, or get the Serial9 adapters and go coilover. Zcarparts.com also has 1" sway bars, and the poly bushings set.
Wow... lolPerrenial Badass wrote:It is my horse. Look at it. It is amazing.http://shutupwomangetonmyhorse.com/
Modified by Perrenial Badass at 5:35 PM 2/21/2010
