N/A S14 SR (TO) Turbo revs to 4.6k and falls on face.. fuel cut HELP!
E7-S14
Car: ess 14 foo!
my setupS14 N/A SR20DE+T t258psi at 2500-3000in 3rd gear revs to 4.6k and falls flat on faceafr shoots to 16:1 or something.
im running SAFC 2370cc injectorsstock S14 N/A SR fuel pumpS14 SRde Mafsretard 5 degrees from base timingngk bkr7e plugsgapped at .035
swapped in a s13 SR20det Maf and it did the same thingevery single time it hits 4.6 and fuel cuts
any idea whats going on??
been stumped all day on this.running SAFC 2.
Please help!
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Did you have the ecu rom tuned?
E7-S14
Car: ess 14 foo!
Stock ECU with SAFC 2
boro drift
I pretty sure you need a tune, also. There's a guy in town here with a KA-T, and he has a rom tune with the safc. My guess would be that the stock ecu is seeing something it doesn't like, and is saying,"f*** it!".
E7-S14
Car: ess 14 foo!
so your saying i need a rom tune?
what places or who can tune an S14 N/A SR Ecu for boost?i don't know much about rom tunes. and don't know who to go to. for it.
i thought the safc would be able to handle it on 8lbs.ive heard of guys running KA-ts off afc's and not having a problem like this.
any other ideas?
boro drift
If I were you, I would contact Jim Wolf Technologies directly and ask them. If anyone knows, it's those guys.
E7-S14
Car: ess 14 foo!
Seishuku! i need your HELP HERE!
E7-S14
Car: ess 14 foo!
boro drift wrote:If I were you, I would contact Jim Wolf Technologies directly and ask them. If anyone knows, it's those guys.
JWT doesn't support N/A SR+T ecus. unless they do secretly.it says they dont on there website
boro drift
I just checked Enthalpy's site, and they have a tune for the DE (turbo).
http://www.rs-enthalpy.com/ecu.htm
edit- Whoops! I read that wrong, it said KA-T s14, sorry.
Modified by boro drift at 6:42 PM 6/3/2009
E7-S14
Car: ess 14 foo!
yeah for the KA24DE (turbo)
i may go Nistune.. but i need a car and i dont have the extra cash to drop on that now..
boro drift
Is there anyone else on NICO with a SR20 DE+T?
E7-S14
Car: ess 14 foo!
yeah Seishuku does. in his corolla.S14 N/A SR+T just like mine
wishing he'd chime in.
were on the last stretch of my turbo build only to get caught up with this crap.
boro drift
I hope you get it dialed bro. Sorry that I wasn't much help.
Good luck!
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
It's not a Corolla...
As far as I know, you can't do a proper turbo setup with just the SAFC.I wouldn't want to anyway, not when you're dealing with boost and 10:1 compression.
I can help you with the ROM tune, but I'm not really sure on modifying the ECU for a daughter board for the ROM chips. I understand how it works and all, but you really need to contact Calum Johnson ([email protected]), he can help you figure out the hardware part.
Now, if you really want to do it with out a ROM tune, and I still don't really recommend this either, but with an MSD boost timing master (BTM) and an 8:1 rising rate fuel pressure regulator (RRFPR or FMU). I know a few KA+T guys do this is fairly decent success, but it will only get you so far.
But don't keep driving it like that for sure, you'll melt a hole in a piston.
E7-S14
Car: ess 14 foo!
we figured it outthere was a leak somewhere and some setting on the afc was off.
made 180 on 7lbs.i need-walrboro 255 fuel pump-Nistune ECU.-FMIC..
then ill be happy.i cant run the safc for long i know.
Seishuku
I guess as long as the AFRs are at least 11:1 when in boost, you should be ok. I would keep an eye on the timing though.
Hook up a laptop and do some consult logs, if you can. Graph out the timing curve, make sure it's not putting too much timing in when under pressure.
Here's my timing map for reference:
Just keep in mind that I don't know what that map would do with out water injection to keep pinging away.
E7-S14
Car: ess 14 foo!
im running a little lean up top.as im still running stock fuel pump. but that should be fixed
i think now im running 12:1 for the most part.then leans out a tad on top end.
i cant mess wth timing until I get nistune
