N/A ka24de with bolt-ons - Dynoed
psi240
Car: 1997 240sx
Hotshot header, 3" testpipe, 3" exhaust mild port on intake manifold All emissions devices and vaccum lines removed / egr blockoff plate Butterfly's removed.Intake w/ HKS filter 94 octane pump gas
Everything else is Stock! It made 158 whp / 155 tq
4th gear pulls on mustang dyno
heres a vid of one of the pullshttp://www.youtube.com/watch?v=7XNbT2OAcJg
brandonDavid
Car: 1992 240sx, 1992 D21
ain't too bad at all sir.
24DSXY1
Car: 1991 NISSAN 240SX
Nice! Now if you would just throw in some Brian Crower 264 cams in there so we can see a solid dyno with those cams on a n/a ka.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
and a back fire? wtf!
needmorenissan
Car: 1993 Nissan 240sx and to much to handle
nice man that gives me hope!
24DSXY1
Nice! Looks like you got vtec at 5k rpm. The weird thing is that at I actually feel a little boost on my n/a 240 at that rpm. almost vtecish
DroptopDrifting
Car: 94 240sx limited edition se convertible
please dont ever compare my car to a honda.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
DroptopDrifting wrote:please dont ever compare my car to a honda.
your car is as good as a honda
24DSXY1
I did some searching and found another n/a ka dyno with the same bump up in hp at 5k rpm and someone said it was cause there was no knock sensor on the motor so the ecu retards timing until 5k then return back to original timing, hence the little hp boost. He also said if the knock sensor was back on the motor it would have made more power. So did you remove your knock sensor too?
motoman399
Car: 98' wrecked (RHD coming soon) 240
so do you have some kind of intake or is it stock? those arent too bad for what you have done to it. i have almost the same. i have 2.5 exhaust and no port job. but i have a flywheel.
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
Nice! Gotta remove all that stuff on mine and get headers
Marahutay
Car: 1991 Nissan 240SX Fastback
24DSXY1 wrote:I did some searching and found another n/a ka dyno with the same bump up in hp at 5k rpm and someone said it was cause there was no knock sensor on the motor so the ecu retards timing until 5k then return back to original timing, hence the little hp boost. He also said if the knock sensor was back on the motor it would have made more power. So did you remove your knock sensor too?
for the longest time i thought i might have had a compression issue because of that kick at 5K RPMS. Although, happens for me at 5600 consistently.
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Those are good numbers for 94 octane.I made 162 whp on 95 octane and all emissions still intact, so your numbers aren't bad at all.
Marahutay
Bigvinnie wrote:Those are good numbers for 94 octane.I made 162 whp on 95 octane and all emissions still intact, so your numbers aren't bad at all.
not to go off topic but how much does the the octane level affect performance levels on a 100% stock motor? JW if its worth it to buy the premium.
Bigvinnie
Marahutay wrote:not to go off topic but how much does the the octane level affect performance levels on a 100% stock motor? JW if its worth it to buy the premium.
100% all stock motor with no ecu tuning, not much maybe a 1% gain using higher Octane.
Now if you tune your ecu, adjust a/fr's on a 100% bone stock motor maybe up to 2% gain in power.
Fully bolt on stock block and ecu tune maybe a 4% gain.
Thats pretty much what I have seen from this engine.
