90's250sx »
https://forums.nicoclub.com/90-s250sx-u156370.html
Mon Mar 15, 2010 7:02 pm
Ok everyone has talked about n/a builds how they cant reach this amount of horsepower or whatever. I am wondering if there is anyone out there that doesnt really have a budget but just took the time to save up the money and do a fully built stroked ka26de? I have looked up alot of stuff on this and kinda have a parts list..... BC 2.6 stroker kit with the race bearings and the 280,000 psi fastners with a 10.5 to 1 comp, .5+mm valves, arp studs, oil pan from excessive, toga hv pump, port and polish, excessive manifold, bc cams 272, adjustable cam sprockets, bc dual springs, 300zx maf and throttle body, spacer, 740cc injectors, nismo fuel pressure reg., 255l/hr fuel pump, ati dampener, 3 piece lightweight pulleys, 11lbs flywheel, stg 4 clutch, one piece 15lbs driveshaft, axle bars, lsd, plasma booster ign., 10mm wires, irdium plugs, dyno tuned. If anyone has done something pretty close to this and taken the time what kind of numbers are you getting? I know its expensive but its all in what you want not what everyone else wants or does.
