DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Wed Sep 27, 2006 8:11 am
i should be at about 180whp is the coming months, and its all going to be for under 1G. dont believe me?
cam gears: free. see my new article.Cams: i use 248/248 with the gearsPistons: 90 SOHCs, with new rings you shouldnt spend mroe than 300 dollars.Intake Manifold: if you odnt know the deal on this one already look around. i built the first one for 30 dollars, ad my next one will be under 50.header: dc sports 100 dollarscat: i gave it a coat hanger abortionexhaust: SSAC n1 dual 3in 183.82 shippedECU: me and live edit are about to get down. should cost about 100 dollars.Intake: cut honda pipe and ****ty APC Greddy knockoff with cold air box and headlight scoop 60 bones.No AC: freeSR 370s: 100 bones ( you will max out your stocks at 180wheel)
thats about exactly 1000 dollars. i have the most weight reduction i can live with. rims, tires, clutch, blah blah woof woof. the moral of the story is this:
if you dont think my 1000 dollar in mods will outrun a stock SR swap, youre soarly mistaken. I'm not willing to throw down the 150 on a flywheel, or the 100 in pulleys, or the 300+ in driveshaft. Thats obviously what i want, but i just cant afford it yet.
i'm just doing my best to see what we can do to this beast for cheap. i'm doing my best to bring all of this info to you. Top End Engineering (or is it performance?) sells a 210hp (probably crank) KA24DE. Look at all that thing has, and its not much. the only thing im going to be missing is headwork, and im going to do it for 3000 dollars less.
so just from the list i stated earlier, its a good place to begin research.
