11.1:1 is very streetable, anything after 11.1:1 can become a problem.You can have problems with idle, and lowend power. 11.1:1 is a pretty comfortable setting for a good jump in horse power. I just hope your not worried about smog, the NOX starts to go through the roof after about 2200RPM.JesusLikesKFC wrote:well from another post i had a guy telling me11.1:1 is very streetablewith
Honestly in respects to JWT they are crap, I think we can all agree. Pretty much JWT does what is called Safe Tunning. They will only tune the ecu so much to safegaurd against damaging the engine at higher fuel dumps and ignition.If you don't know that much about ecu tunning start off with a simple piggy back like an SMT6, or the Apexi SAFC, they are pretty much user friendly devices that just need a slight dyno tune.SAFC though doesn't give too much funcionality, and even in getting higher HP numbers the engine can run slightly on the gass guzzling richer side.thekage wrote:Yeah the stuff on ecu tuning can be a little confusing. But its good info to know. Save the hundreds of dollars from getting JWT to tune your ecu and learn how to do it yourself with under 200 bucks and your home computer. Then you can always adjust it if you want and you don't have to pay anyone to reprogram it again and again...hit up DeviousKA.. he sells stuff for both the e and de.. and has tons of knowledge and I think he works for a nissan preformance race team.. he runs the ecu tuning site I showed you to. He can definitaly get you what you need.
iirc, NOX will drop if you use synthetic oil, well it helps the NOX not go through the roof. and thats with 11:1:1 cr.Bigvinnie wrote:11.1:1 is very streetable, anything after 11.1:1 can become a problem.You can have problems with idle, and lowend power. 11.1:1 is a pretty comfortable setting for a good jump in horse power. I just hope your not worried about smog, the NOX starts to go through the roof after about 2200RPM.
I asked this question in another thread I started, Insanity INC wasn't to shure. But now I guess in that case, I'll be getting ready for my cali smog check.... I knew that the synthetic would drop NOX, when regular petro oil boils and gets hot it increases NOX. I knew synthetic doesn't burn the same, I was already under the assumption that this could pass my smog check.X20-A wrote:
