I did the swap bc my old one was shot like the coil pack and some injector connectors. So I used one from my buddy's old z that he did a tt swap on. I'm going to check the iac and check the tps as well since I retrofitted that too.Recian wrote:that would be a lot of issue. not to mention 95 is obd2 and 90 is obd1. Plus these harnesses are finickey and very fragile due to age and the bends they make on the back of the engine I wouldn't be surprised if you have a bad harness. My car was doing the same here recently so I've studied up on idle issues. First check for any leaks. If you have none or after repairing them then you can adjust the idle with a screw on the IACV at the back of the driver side intake. The FSM says to adjust TPS to spec before doing that, basically saving the screw as a last resort but it is possible it's been messed with. If you can screw it all the way in and car doesn't die you have a vacuum leak. Also check for dirty throttle bodies. My car used to idle at 2200 cold. Couldn't idle through the neighborhood when it was cold. I've tuned that screw back and it idles at 750, 650 with lights on and 900 with a/c on. 1700 when cold.
Mine likes to stay at 2200 after you take it out of gear and coast but it's not as bad now and drops soon after it realizes you're slowing down. May need to look into the IAC and see if it's not clogged or stuck open too. These cars use a 2 valve system in the IAC and it's a bit more complicated than it needs to be honestly.
To correct you 96 is when the switch to obd2 happened not 95. However the op hasn't stated manual or auto for his as well as the car the harness came from, but just cause it's a different year doesn't mean it won't work. either way though the the 95 has the new style connections for the injectors, cas. Etc so I feel some info is missing to help further diagnose the issue.Recian wrote:that would be a lot of issue. not to mention 95 is obd2 and 90 is obd1. Plus these harnesses are finickey and very fragile due to age and the bends they make on the back of the engine I wouldn't be surprised if you have a bad harness.
My car is a '90 5 speed and the harness came from a 95 auto. I also did the new injectors to old style fuel rail conversion before realizing some of the wires were f*cked. so instead of trying to trace all of them i just used my boy's spare harness to see if it would work. I completely forgot we used the auto ecu. Now im pretty certain thats the culprit. I disregarded that since the car has been running fine aside from the idle issue. I just need a 5 speed ecu now.Z-owned wrote:To correct you 96 is when the switch to obd2 happened not 95. However the op hasn't stated manual or auto for his as well as the car the harness came from, but just cause it's a different year doesn't mean it won't work. either way though the the 95 has the new style connections for the injectors, cas. Etc so I feel some info is missing to help further diagnose the issue.Recian wrote:that would be a lot of issue. not to mention 95 is obd2 and 90 is obd1. Plus these harnesses are finickey and very fragile due to age and the bends they make on the back of the engine I wouldn't be surprised if you have a bad harness.
I'm definitely going to do that this weekend. and also post some pics of my car on the forum of how she's coming together.DCaff300ZX wrote:I believe that I was told by my 5spd swap guy that the auto ECU can be used with the 5 speed swap, as was the case with my NA, but not the other way around so you should be OK with the 95 auto ECU. My NA also went through the idle issue thing years ago, and the culprit was hoses and IAC cleaning, luckily. Spraying WD-40 into it a few times fixed it, unlike currently with my TT.
I'd concentrate on the IAC and throttle body cleaning first, then as I am currently doing (unsuccessfully so far as well) follow the FSM tests of the related controllers and such looking for the issue. I've heard and read of a lot of IAC issues related to idle and as stated by another above, the system is overly complicated and therefore a PITA to deal with without instructions from the FSM.
