fraz »
https://forums.nicoclub.com/fraz-u19354.html
Sun Jan 16, 2005 9:39 pm
If its a rwd ca, the ecu pinout is the same as the rwd det, just missing the turbo associated stuff, which is not a lot anyway.
To make a N/A DE go good, you need to fit a 60mm throttle body and get the manifold ground out to suit. These T/Bs come on N/A auto sr20de and not much else in the states i think, Oh yea, also on fwd u12 ka24e
Get the compression up to 10.5, run a set of headers, rb20det injectors, they are same high impedance, but 10cc's bigger, give the fpr a tap on the back with a 3/8 extension to increase the fuel pressure.
You can also run a fwd u12 ka24e afm as it is a little bigger. I dont know if the s13 ka24e has the same afm. You have to muck with the wireing as the ka afm is 3 wire and the ca is 4 wire.
Get the cams reground, and advance the intake cam.
That will give your datto a good boost.I have a mate in new zealand that had the same setup, 5 speed s13 box, r200 lsd, shocks/springs/17's and it went like a rocket
