C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Jul 19, 2006 10:19 pm
I'm all for being different, but depending on your power goals, going FI with a low boost set-up can be less stressful on the engine. I'd maintain the OE redline. This will probably be the biggest factor as far as reliability is concerned. But don't expect much of a difference in HP without being able to rev higher.
As far as going SC later, don't use any method of spacing the heads. You can actually do more harm then good. Combustion chambers are designed with quench areas where at TDC, the piston edges come very close to the top of the combustion chamber. This pushes a large amount of the mixutre to the center of the chamber for a more efficient burn. The quench area has such a small amount of space that any air/fuel in it is too cool to burn due to the proximity of the cooler surface of the metals surrounding it. This helps prevent detonation with the high compressions modern motors run. Opening this area up can allow detonation to occur more easily. Add in FI and you could end up with a recipe for disaster. While the quench area can still be more than the factory setting and still prevent detonation at TDC, bear in mind that TDC only occurs for a moment in the combustion process. The moments just before and after TDC still have very high pressures and heat and you want to make sure detonation doesn't propogate during these crucial times.
Moving to a lower CR piston is a much better way to lower CR.
Personally, I'd be concerned with trying to run 11:1 compression in the first place. Especially on a factory ROM tune. The VQ in the Z is pretty high strung already. Pushing the envelope here may not be wise. I'm not saying it won't work, but I don't see this as setting out in a safer direction.
Either way, let us know how it turns out.
