racingtiger03 wrote:Good luck man. I have the same thing, and I had the dealer rebalance all 4 tires. I still have the vibration, and am going to bring it to their attention AGAIN next oil change. (took 2 hours last time, no way in hell am I sitting there that long again.) That said, I don't do burnouts, but I do push her pretty hard in a few corners on occasion.
Modified by racingtiger03 at 8:42 AM 7/30/2008
Garbage excuse by Nissan. Its not hard to balance a tire, but its really easy to screw up. If its not aligned perfectly on the balancer, tries to balance with any weights still attached, spun to fast, it wont balance correctly. I go through a routine of; deflate the tire, take off wheel weights, unmount the tire from the rim, remount it, refill the tyre with nitrogen to the max psi, then put it on the balancer. Helps for the most consistent balances
