Postby
91FairladyTT »
https://forums.nicoclub.com/91fairladytt-u192384.htmlMon Oct 24, 2011 9:12 am
So there is a little black hose with blue writing I found just hanging near the battery and I can't figure out what it is supposed to attach to. Any advice is appreciated.
It is attached to to back edge of the engine bay and runs all the way across to the driver side to...
Looks like the tube runs to the gray box in the bottom right of the last picture. Im not sure what the box is either.
Postby
BigTDogg (MA) »
https://forums.nicoclub.com/bigtdogg-ma-u74746.htmlMon Oct 24, 2011 10:06 am
Does your factory boost gauge work? The little black box with the grey connector in the last pic is the OEM boost sending unit. That's most likely your factory boost gauge hose.
Postby
91FairladyTT »
https://forums.nicoclub.com/91fairladytt-u192384.htmlMon Oct 24, 2011 11:01 am
The boost gauge works. I don't think it goes to the Black box it's the one next to that that is all gray. I can't tell for sure I'm bringing some tools home with me later from work so I can get a better look. Someone else said mabey the AIV has been deleted and it's pretty common? Can anyone confirm that? And what is AIV?
Postby
BigTDogg (MA) »
https://forums.nicoclub.com/bigtdogg-ma-u74746.htmlMon Oct 24, 2011 11:20 am
AIV = Air induction valve, used to bring fresh air into the exhaust to pass emissions. Eliminated in 1993 IIRC.
I'm pretty sure the grey electrical box is your wiper control box, or has something to do with the wipers. If the hose goes into the wheel well through the hole below there, then it's for AIV.
Postby
91FairladyTT »
https://forums.nicoclub.com/91fairladytt-u192384.htmlMon Oct 24, 2011 12:04 pm
Alright it probly just runs underneath that box to the fender I just couldn't tell with the light and the tight space. Update later with what I find. Thanks for the help.
Postby
91FairladyTT »
https://forums.nicoclub.com/91fairladytt-u192384.htmlTue Oct 25, 2011 8:40 am
Alright dug around and found the T it goes on. Looked at the exhaust and all the AIV stuff is connected so I don't think the guy who owned it did the delete... Must have just popped off. The car has an ecu so from what I've read it doesn't use the AIV anyway? Thanks for the replies.
Postby
91FairladyTT »
https://forums.nicoclub.com/91fairladytt-u192384.htmlTue Oct 25, 2011 11:18 am
So I had it reconnected and Started driving and noticed the check engine light was on so I pulled the hose back off the T restarted he car and now no CEL?? Why would it make it come on if it isn't being used?
