not that I am aware of. I can't find a female connector to connect this thing to. If i sent you a picture on my phone, could you verify?s13gebala wrote:is it by the p/s reserve? i have the same thing..
X2placham wrote:I'm going to take a wild guess here and say that, that might be turn signal flasher
http://www.240edge.com/manuals/91-94_240sx/el.pdf use this link for your cluster and tail lights problem.
See what your missing or is not powering on, and try to trace it back on paper first. Than go back to the car and, start testing.
Does the thing above look like this
Because it definitely is not a relay, more of a circuit breaker.
GL
Dont want to sound like I told you so, but didn't I tell you so, in both your posts. I scare my self when I'm right, this happens often. Now where is my prizejdm_master_X wrote:i figured out all three problems all night. here's what they were:
-tail lamp: broken splice located at lamp furthest to the left. reconnected the wiring to a new splice point. let there be light!
-flashers: this part i brought up was the reason the flashers were not working. put it in and voila!
-cluster (digital/analog): wiring at the fuse box was frayed slightly (behind the fusebox, you have the flasher unit and two blue relays. the wires on the relays were exposed enough not to get power to the cluster. love tapping it allowed me to get it running. repaired that piece.
so all in all, thanks for all the help, guys! i owe you all a big one.
