SILVER97LE »
https://forums.nicoclub.com/silver97le-u12653.html
Wed Aug 31, 2005 2:02 pm
97 240sx -
With no rhythm or rhyme, my car will start making a loud humming noise and after probably 5 minutes with the noise, I start getting a relatively small amount of dark colored smoke. Then for no reason the noise will stop and the smoke/smell go away immediately. The noise and smoke are coming from the side of the engine with the battery / alternator. It is coming from the front of the engine. Unfortunately the fan makes figuring out exactly where the smoke is coming from impossible.
If I were to bet, I would say it's the alternator, but can it smoke? Could it be wires burning inside? I have never gotten a warning light for it.
Although it does have a oil like smell, it goes away immediately when the noise ends. Also, it is not the belts because they look perfect with no wear on them. I want to get it fixed, but it never does it when I near a place were I can take it in.
Other things - 1)Sometimes I will drive for 15 miles and the noise/smoke are still there, but sometimes it lasts only for a few minutes.2) It happens when the car is hot or cold.
Please give me some guidance on this one.
If I don't write back, it's because I died from smelling to much smoke while trying to figure out the problem.
