IMH »
https://forums.nicoclub.com/imh-u110135.html
Wed Dec 31, 1969 5:00 pm
Which ever H190 differential you end up using will require the use of the 320 side gears and 320 axles in order to use it in a 320. When I did that swap on my 320, I recall that the 320 axles were shorter than the later 520, 521, 620 etc. Check with Tania (vindats on this site). Maybe she has a set of 320 side gears that you could send to the shop along with the differential.
