panda56 »
https://forums.nicoclub.com/panda56-u18714.html
Thu Jul 15, 2004 6:49 pm
alright, iv got a decent question for both 180fan and Nismo1182... i have a 1989 240sx with an SR20DE under the hood and wiring is done through a KA24DE harness...do i or do i not cut and re-pin the two plugs behind the stock battery tray. also to all you out there with the KA24DE, does anyone know where i can find a wiring diagram or electrical map for the KA24DE, i feel it would aid alot in the wiring, although most of wich is either direct plug in, or switching the type of plug. right now im struggling with a large plug with 8 wires in it that ends up by the throttle body, also a small plug with 2 wires,, i think one is white in the same area. im under the impression that i have to repin the2 plugs because right now i have absolutly no spark which i think i should, but according to heavy throttle one of those wires is main ignition, another ecu power,,, i bet i need those.thanks for any help you can provide
