canadians14 »
https://forums.nicoclub.com/canadians14-u8064.html
Mon Sep 06, 2004 11:47 am
I'm almost done installing an Fmax Stage Two Kit on my '96 240 but i can't figure out the function of two hoses that i might need to re-route. They both originate near the throttle body, the thicker hose coming from above the throttle body and the smaller one coming from below. My main question is what do both of these hoses do? On the stock setup they both entered the intake stream before the throttle body and only saw vacuum. Since the Fmax kit routes the bigger hose to the same spot, that hose will now see both vacuum and boost. Any problems there? Also Fmax does not provide a mounting location for the other smaller hose ( that i can tell ), so i'm not sure what to do with that hose. Any setups or opinions are much appreciated.
