Mystery drain plug?
straxxus
Car: 2016 Nissan rogue SV
Hi, I'm looking for information on what exactly the drain plug pictured here is for?
http://imgur.com/a/yGTd984
The cvt drain plug is just out of frame and is black, and the oil pan is on the other side of the exhaust pipe.
Its important to note that I undid this plug when I was doing the first oil change after I purchased this car about 50k miles ago, and drained what looked like engine oil from it. I am concerned this may be cvt fluid, but I haven't noticed any ill effects in the 50,000 miles since I drained it.
Anyone know what this is for?
Reason: FIX IMAGE LINKS
mpattdu
Car: 2008 Nissan Rogue SL AWD
Hard to tell from the picture. Does your Rogue have AWD? If it does, you might have drained the transfer case.
straxxus
Yeah it's a 2016 rogue sv awd, and it seems like I would have noticed in 50k miles if the transfer case was dry but I'm no expert
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Pretty cool if that was the transfer case drain bolt.
First generation owners had to deal with a hex bit to remove the drain plug.
On top of being a contortionist to remove the fill plug with the same hex bit.
Major pain in the a $$! :cry:
KoiMaxx
Car: 2017 Rogue SL AWD
It looks like the CVT fluid overflow plug (refer to FSM TM-189)
Return to “Rogue Forum”
