fate2k »
https://forums.nicoclub.com/fate2k-u10657.html
Tue Dec 30, 2003 4:22 pm
For the past day, I've been noticing steam coming from under the hood of my 91 240SX fastback. (m/t)
Under further examination, I see coolant splashed against the battery, the inside of the lower fan shroud, on top of the A/C sightglass, and there is a thin pool of coolant between the top of the radiator and the foam liner on the bumper side. The pool is not boiling hot, so I'm guessing it is just collecting there rather than leaking from there.
I can run the car with no steam, or leaks untill I shut it off, then I hear an odd "squish, squish, slurp" sound come from near the radiator, followed by a small cloud of steam from between the upper radiator hose and battery.
I've checked all the hoses and I've found no leaks, The lower radiator hose and Water pump were replaced about 3 or 4 months ago, and show no signs of failure.
Any ideas about what is causing this?
