robk wrote:Hello,
I am new to the forum. My G35 has started something inexplicable. No one can detect the problem. I changed the tire and the problem ceased but has since returned. Here is my girlfriend to describe what is happening with the car she drives:
After the car warms up, normal speed it begins to shake starting under the automatic gear lever. Two mechanics drove it and their reply was " I have never felt that before, they had no idea. It shakes so bad you can not see in the rear view mirror! I also, replaced the brakes and tires. It started after I got a large staple in the back left tire, driver side, I replaced it with another new tire going broke trouble shooting please help! Thanks Kelly
If the vehicle hit a pothole and damage to a rim occurred that could account for the shaking and vibration.
Go to a reputable tire shop and have the tires removed from the rims. Have both rims and tires carefully inspected. Remount, rebalance and have a computerized alignment and see if the problem disappears.
If you find either a damaged tire or rim replace them.
Good luck
Telcoman
