redbaron »
https://forums.nicoclub.com/redbaron-u48649.html
Mon Oct 09, 2006 9:45 pm
I just bought a 91 2+2, beautiful body, etc, but the car didn't run right. I has a harsh hesitation on acceleration, but runs fine once you get going unless you lug it or try to rapidly accellerate. After being in a specialty shop for over a week, where they replaced every part they could think of temporarily, they determined that the car is not adjusting the timing properly on accelleration, and the plugs seem to foul a lot.
Also, the car will just cut-out on the freeway interemittantly, even going straight down the road with the cruise control on. Sometimes pumping the gas will restore power, but it just feels like the ignition was turned off. Last time, when I pulled to the side and restarted it, I held the pedal to the floor and the engine reved up and down in a predicatble sequence.. I started it again and it ran okay, but still the stumble.
According to the mechanic, they tested the ECU, cam sensor, TPS, oxygen sensors, maf sensor and all the fuel system components. They say this is not a common Z problem...
