mykeo4 wrote:boost boy i see that u have da ca18det in ure sentra i am getting that motor for my car with the 5 speed transmission and everything. my only concern is what else do i need to get the old engine-trans. out and the new engine-trans in. besides a reliable mechanic is their any specific parts. also right not i have a automatic but with the ca18det i want to convert to a manuel so what would u suggest to me are the things i need and should buy to swap the engine and convert to a manuel trans?
Hmmm, E16 to CA18DET swap? Sounds like you got your work cut out for you. Basically, you'll needa complete 1988-89 nissan pulsar SE (5-spd. of course) to even begin trying to pull this off. From the pulsar you'll need it's:
Clutch pedal.Throttle cable and pedal.Shifter and rails.Brake pedal (because your's is an auto).Transmission mount bracket.Right side engine mount bracket.Rear engine to transmission to rear lower mount bracket.Front dog bone bracket.Make sure you get all the bolts and nuts associated with these parts.If your engine comes with a transmission and it's one with LSD, you'll need the axles that comes with that transmission.If you use a pulsar transmission, you'll need the axles from that pulsar.Brand new 1988 nissan pulsar mounts and there are 5 of them.Wiring is another issue as I don't know exactly what you're getting because the person or people don't know exactly what they're getting until it gets to to them. Most don't know much about the engine anyway as it comes in 3 versions for the fwd. I hope you get the right engine set the first time which is the 3rd gen bluebird motor or you're going to be very disappointed with older version which PITAto put in. Good luck with this and if you need anymore help, you know how to find me.
Dee
