Please check out the current issues with the car and let me know if you have any feedback as to what it may be. Thanks again for all your help guys!
Things that I have done so far:
120k factory recommended service a week after buying the car (belts, spark plugs, pulleys, seals etc.)
New Battery (yellow top)
JWT Pop Filter installed
New rims/wheels
New exhaust
HIDs, and LED upgrades all around
Lots of exterior buff/polishing done
New side blinker light housing and lights (Clear)
Small weight reduction getting the spare/jack/back cover out
Things that I want to have done:
New Leather seats
New Diff/Trans/Brake fluid
New Rotors/Brakes
JDM Clear rear lights (orange delete
Smoke/Plastidip top brake light thing (turned red)
Fix rear panel rust (posted about this before, temporary look fix by using some spare vinyl wrap for now
Fix acceleration whine issue (SEE BELOW!)
Fix poor acceleration from 0 (SEE BELOW!)
Fix random check engine/car shake issue (SEE BELOW!)
Issues:
Acceleration Whine/issue: Whenever I have the car from cold start to about 45minutes of driving, every time I accelerate, there is somewhat of a beeping/whining noise coming from the rear of the vehicle. Based on my research, It can be the fuel pump, ABS system, or something else. The symptoms point to the ABS because I feel it is coming from that rear right area of the car. Any other ideas as to why this can occur? The sound also happens when I cold start the car and turn the key. Makes the noise for about 3 seconds on startup.
Poor acceleration from 0: I have been trying to do some tests on the acceleration, and whenever I floor it at zero, It seems to lag/hesitate from 0-20. After automatic sets it into second gear, it starts picking up drastically. I know the NA isnt supposed to be an insanely fast car but it does seem there is an issue here. Oil pressure issue?. I might have a vacuum leak? What are some things I can check?
Random check engine light/car vibration: This seems to happen maybe once every 10 drives I have with this car. Usually occurs after a sharp turn but I dont know for certain. The car starts "chugging" and vibrating heavily on idle. The check engine light comes on immediately, and the car is still driveable but it just does not sound good at all. I usually put it in park somewhere safe in a parking lot, and after revving it once or twice, the shaking and the light goes away. I have very little idea as to what can be the case of this issue. Bad spark plug? I had those replaces with new ones so I dont know. Injectors? Engine Temp sensor? I think this may be the culprit because whenever I wiggle around the connection to the coolant sensor plug, the car seems to go up in RPM for a bit then go back down. Might be a faulty coolant temp sensor or connection?
Thanks for reading, and any help is appreciated!
