My Z31 gets to operating temp on the road then stops
A home for 1983–1989 300ZX owners!
OZZ31
Car: 1983 Z31 Turbo HZ31000383 RHD 2 seater
Hi, i am just new to the forum please see earlier topic, my Z31 has been running like a dream until 2 weeks ago i got 5 miles into my drive and the engine just cut out, and there was a audible ticking under the bonnet from this part Image it is directly above the coil, i disconnected the battery then reconnected it and the noise went away, she started again and i got her back to my mechanics, the following day i took her for a short drive 4 miles and when i pulled up at my mechanics the same thing happened, it keep on doing it but then stoped cutting out ( i think it was the engine (turbo)cooled down enough for it to stop happening) .
Last weekend thinking it was fixed the same thing happened, i poured cold water over the Airflow, and crake sensor and the one under the coil but it did not fix it. so i sat around until the engine cooled down and the engine started again and i got home before it died again.
I checked the self diagnostic on the ecu and it came up with 14, 23 24 and a 31, i know the a/c is out of gas (31) and the (24) from the auto to manual conversion, i am not sure if the 23 or 14 would cause the engine to cut out ounce the engine got to full temp,and the part in the photo would tick .
I have ordered a new Throttle, crank angle sensor any other suggestion's would be much appreciated
Cheers
from Dave downunder
ezb57e
I remember those crank sensors as being temperature sensitive. I think you are on the right track.
ezb
G-E
Car: 1. 1987 300zx Turbo-swap, SF interior, koni rallisport springs/struts, msa swaybars
2. 1997 Sebring coupe
3. 1987 300zx 2+2 becoming a caged racecar with RB swap...
That looks like some stuff the usdm version didn't have... but if it stumbles and dies after reaching temp, it's likely chts just beside the bypass hose
OZZ31
G-E wrote:That looks like some stuff the usdm version didn't have... but if it stumbles and dies after reaching temp, it's likely chts just beside the bypass hose
Thanks ezb57e and G-E,
G-E what's a chts just beside the bypass hose?
ezb57e
I think he means Cylinder Head Temperature Sensor.
The terminals on those get corroded a lot too.
OZZ31
Ah thanks ezb57e for that, i will look at that one if the other replacements don't work.
Return to “300ZX (Z31) Forum”
