Hello everyone! I'm new to the forum &I have a 93 Z convertible that I'm having idle issues with! I just had all new jecs 270cc injectors, injector connectors, NGK plugs, EGR, pcv valves & hoses, IACV hoses, fuel damper, FPR & rubber fuel lines, fuel filter, water pump, upper & lower rad hoses, both coolant sesors replaced last week. The car runs beautiful on the road but when @ idle it bounces ( surges) and almost wants to die. No ECU codes. I have a new TPS coming on Friday. Is there a way I can test my MAF to see if it is functioning properly. When the car is idling, if I disconnect the MAF it idles better. I took it out over the weekend and cleaned it with CCR MAS cleaner but no change. The IACV & air reg was the next thing I was going to tackle. Are there some tests that I can do for them as well. I did remove the hose between the REG & the IACV and sprayed some WD-40 and that did not help.
I would appreciate any help you guys could give me!
Thanks
