My Z - ride of the month
A home for 1983–1989 300ZX owners!
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
Here is my z31 turbo. Soon I turn up the boost & go to the dyno to find out what she puts down. Then off to the drag strip to better my 13.3@106mph.
T3/T04E turbo w/ceramic BB -turbo exh. housing/exh. manifolds & turbo elbow coated with SwainTechnologies heat barrier coating -MSD 6A ignition module-boost referenced fuel press. regulator-240sx TB -gutted intake manifold-engine rebuild with 27,000 miles on it -ported & polished heads/intake & exhaust manifolds -copper head gaskets -K&N cone filter -UD pulley -alum flywheel -RPS clutch -Apexi AVC-R/AFC-AEM Air/Fuel gauge & O2 sensor-Autometer oil press./boost/oil temp./water temp. gauges -3 inch HKS exhaust -3 inch downpipe & testpipe -88 5sp/LSD/fr & rear control arms -88 front bumper/headlights/hood-200zr hood scoop-TBO front lip-JWT 450HP ECU/injectors/Walbro fuel pump/Cobra MAF -18x8/18x10 wheels 245/40 & 285/35 AVS Sport (street) -17x9 & 17x9.5 Enkeis with A032Rs (track) -stock 16x7s with Hoosiers (autocross) -Spearco I/C -urethane bushing everywhere & alum subframe bushings -Tokico 5way struts/springs -MSA sway bars -fr/rear strut tower braces -roll bar & harnesses -TT front calipers & 88 vented rear rotors & calipers -aluminum transmission/diff mounts -urethane engine mounts-custom short shifter -Blaupunkt Secure Digital card & CD player (from Lotus Elise) -2 amps/10 speakers-Shiro/Recaro seats & Shiro door panels-Maxima Anniversity Edition shift knob
Modified by Mark86T at 9:51 PM 5/16/2006
skatermatt180
Car: 1990 240sx fastback
I dont really like the z31's, but this one is the SH*T!! I love it!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
very hot, congrats on ROTM, I gotta get me another Z31 soon
Mark86T
evildky wrote:very hot, congrats on ROTM, I gotta get me another Z31 soon
Z31 turbos are the best cars. They cost less to get them to go fast than any other Z. Definitely best bang for the buck. I sold my 95 TT to keep & build my Z31 turbo.
SICK, SICK, SICK!!!!
Mark, you did such a great job on that car.
WideBodyCharlie
Car: 77 Datsun B210, 74 pl620, 98 Frontier, 94 Altima, Nissan Cube
very nice z! i love everything about it. i like the black wheels on there.
evildky
06 Nissan 350Z GT
I have o disagree, the S30 is the cheapest car to make fast, it's also easier to add an intercooler to the early chassis, and that fact that it weighs about 1000 lbs less is a big help as well, building another car that should run 11's for under 2k
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
but it's very difficult to find one for cheap that isn't rusted to ####.
And since they didn't come with turbos, you also need to find a turbo motor and yadda yadda yadda.
Everything else makes sense though.
sharjt
Car: '06 G35 Sedan 6MT
'83 Datsun 280zx turbo - RIP
You're Both wrong cheapest to make the fastest and easiest to get the parts for is definatly the s130.
That is IMO.
evildky
06 Nissan 350Z GT
heh, the S130 is a bit heavy but if you can find one that isn't wrecked or rusted, personally I havn't found a donor with a shell worth saving yet, and if you know what your doing with the L28ET all you need is the manifold awhich you can buy tubular aftermarket but the stock piece can be had for about $35, just add MSnS I/C and T3O4E
and yeah it's ahrd to find the S30's in good shape thats why mine is rusty bit fast, of course in my area most Z31's are rusted up as well and cost more
sharjt
evildky wrote:heh, the S130 is a bit heavy but if you can find one that isn't wrecked or rusted, personally I havn't found a donor with a shell worth saving yet, and if you know what your doing with the L28ET all you need is the manifold awhich you can buy tubular aftermarket but the stock piece can be had for about $35, just add MSnS I/C and T3O4E
Very true but in my area s130's are very prevalent in the junk yards. Hardly any s30's. So I guess it's just depends on want you have available in your area. Now about 5 years ago here S30s were everywhere. And I don't agree with heavyness. It was 50 lbs less than the 280z according to this.
evildky
06 Nissan 350Z GT
my 240Z wieghs 2105and before I messed with it it was still 2250 (early cars weighed less than the later 240's the listed weight is correct for a 73 model)also keep in mind there was a great deal of variance in the S130's. the early slicktops with manual steering to the later turbo's with leather, all power options, heated side mirrors and auto rear defog etc
and I think the listed weight on the Z32 is a buit low
but in the end, one turbo si a lot cheaper than 2 ! and one cam is cheaper than 2 or even 4!
keep watching GRM for Z's in the $2006 Challange (Including mine) and be watching pinks for a very fast S30 beign built by a group of HybridZ guys (I think they race this weekend)
sharjt
C
evildky wrote:my 240Z wieghs 2105and before I messed with it it was still 2250 (early cars weighed less than the later 240's the listed weight is correct for a 73 model)also keep in mind there was a great deal of variance in the S130's. the early slicktops with manual steering to the later turbo's with leather, all power options, heated side mirrors and auto rear defog etc
Cool Thanks for the info.
Mark86T
Sorry. I guess I shoulda been a bit more clear about my statement that the Z31 turbo is the cheapest to make fast. I meant WITHOUT engine swapping. It has a great platform to start with. TTs are by far the most expensive, 240sx are hard to find in good shape or inexpensive, earlier Zs are hard to find in good shape.
The only reason I have about $12,000 into my Z31 (spent over the past 6 years of ownership) is because it was my first Z31 & I bought things (like springs/struts) more than once until I found the ones I liked best. Now I could build the same car for about $8,000 with all the upgrades mine has. My car is great at the track/autocross & is respectable (for now-it should run low 12s) at the drag strip.
Try starting with $1000 or less to buy the car & build from there. I still think the Z31 would be the least expensive. Didn't Sport Z Magazine list the Z31 as the best bang for the buck outta all the Z cars in one of their past issues???
Just my two cents.
Z31Turbo
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Mark86T wrote: Z31Turbo
Just my two cents but
Z32 > Z31
Z32 TT
Mark86T
nsrZ32 wrote:Just my two cents butZ32 > Z31 Z32 TT
My lil brother would agree with you. I sold him my 95 TT - his dream car. 72,000 miles. Original paint which is perfect & interior is also perfect. There are very few TTs in this original & near perfect condition around. GORGEOUS car. Minor mods like ECU/boost jets/downpipes/clutch/springs. $16,000 is what I sold it to him for. Runs low 14s. (don't care what people say-they didn't run 13s stock)
My car. $12,000 so far. Not nearly as clean a car-I'll admit that. But MUCH faster & would kill it on the track. More unique/rare to find for MUCH less money.
He loves the TT the way it is & I would rather have something faster & less expensive to mod & repair. Worked out great for us both.
I would & will put my Z31 up against any TT at the track or autocross (which is what I built it for) and it is respectable at the drag strip. Unlike most TTs, mine is not built specifically to go straight. It is a sports car after all. Mine will cost less if/when things break & cost MUCH less to build.
Sadly I never find any TTs at the track or autocross. Only at the drag strip. Here in Vegas there will be a large CA/NV meeting of Z cars in mid June. Mostly Z32s form what I've read. The only racing event planned for sure is drag racing Friday night. Go figure. A sports car going straight. No one posted any interest in going to a track event or autocross.
So my personal feelings remain. For the $$$$$ Z31s rule.
Mark86T
evildky wrote:I have o disagree, the S30 is the cheapest car to make fast, it's also easier to add an intercooler to the early chassis, and that fact that it weighs about 1000 lbs less is a big help as well, building another car that should run 11's for under 2k
I met a guy who bought a Z31 turbo at auction for $200. Put a 50 shot on it & manual boost controller & ran low 12s. Said he had about $500 total into it. Next he was going to put a homemade intercooler & 100 shot into it next. But it was a rat. Body was hit & the interior was so torn up it was nasty looking.
Depends on what you are looking to do. If all someone wants to do is go fast in a straight line then any Z can do that cheaply. But doing well on a track or at an autocross & then looking good on the street are totally different.
It's all relative.
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
See most of the TT's around here aren't built for straight lines, so its the opposite of out by you. I hate drag racing anyway, its so freaking boring, auto-x and road course is where its at.
And as for drag times, I ran a 12.86 in my 90 TT with intake, test pipes, catback, and ecu back in spring of 2002. I've seen stock ones get into the high 13's around here.
Mark86T
nsrZ32 wrote:See most of the TT's around here aren't built for straight lines, so its the opposite of out by you. I hate drag racing anyway, its so freaking boring, auto-x and road course is where its at.
I wish that were the case here. We have lots of Lotus Elise, Vettes, EVO, & Subaru at the track & autocross. I am usually the only Z of any type racing. As for drag racing, I like it enough to go out a couple times a year. But that's all I can stand. To abusive on the driveline & too boring waiting in line. I agree that the track & autocross is where it's at. Gotta have the twisties.
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
Your all wrong!!!!
It's the n/a z33 thats best!
duh.
evildky
06 Nissan 350Z GT
in the GRM challange my car will have to autocross as well as drag race, the Z31 is a competent cuildable car as well but it has more weight to overcome and you can't see the turbo from the topside and the exhaust crossover is a nightmare, I've owned ll by the Z33 and the L6 is much easier to work on, and cheaper, the problem is the ancient 30year old design makes for obsticales that must be overcome, cst pistons, no quench area, intake and exhaust mounted to the same side of the head (althout I have gotten pretty ued to working on the stacked intake/exhaust)
AngryScottish
nsrZ32 wrote:auto-x and road course is where its at.
Agreed.
just too bad most of the Z32 owners are like MKiv Supra owners. Fast cars, slow drivers...
and the cheapest car to build fast is a Miata. '91 Miata for like $1500. strip it. slap a turbo on it. add a roll bar. bam. 300hp, 1800lbs and a blast to drive. In terms of Zs... i'd go for the 240z. Something about them gives me goose bumps!
but, i can't talk... i own a CRX, although, I haven't seen any Z post a faster lap time than me at the same track day. :nudge nudge: MARK!
ps. 100 miles down. 900 more to go before my car can beat the crap out of your weak 13.3... bring it, BALLS Challenge!
pss. your car is still damn nice... even if it isn't a Supra or an Elise.
evildky
06 Nissan 350Z GT
the miata's are fun but the turbo doesn't help their complete lack of low end power but they are a hoot to drive and have aobut 30 years less rust to deal with and provide a simple light platform to build from (too bad they are convertible only) but you get their lackluster soapbar styling, I prefer the sexy lines of the Z in all it's generations, it's also hard to find miata's cheap as the spec racers, autocrossers, midlife crisis, and doctors wife all snatch them up
Mark86T
AngryScottish wrote:and the cheapest car to build fast is a Miata. '91 Miata for like $1500. strip it. slap a turbo on it. add a roll bar. bam. 300hp, 1800lbs and a blast to drive. In terms of Zs... i'd go for the 240z. Something about them gives me goose bumps!
Problem with the Miata, it's for midgets like YOU. I can only see the top frame of the windshield when I sit in it.
Faster track time than your CRX? Coming this weekend. Be prepared to being seeing a LOT of my tail lights like you do on the street.
Weak 13.3? That was before the gutted intake & on 14lbs of boost. I now have 17lbs & the intake. Dyno tuning tomorrow night as well. Didn't we line up the other night? Didn't you get to see the back of my car all night?? I'm only gonna get faster.
winez31
Car: 1993 s13 ka24de
congrats on an amazing z. u bassically made what i want my car to be
AngryScottish
Mark86T wrote:Faster track time than your CRX? Coming this weekend. Be prepared to being seeing a LOT of my tail lights like you do on the street.
Well, unfortunately The BALLS Challenge set something straight...
"My 340whp Z lost to aHonda CRX HFatTHE BALLS CHALLENGE"
That's what the window sticker is gonna say
Quote »Weak 13.3? That was before the gutted intake & on 14lbs of boost. I now have 17lbs & the intake. Dyno tuning tomorrow night as well. Didn't we line up the other night? Didn't you get to see the back of my car all night?? I'm only gonna get faster.[/quote]13.300@106mph is still fast... and still far more impressive than Z32s which are pretty slow considering.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
STUNNING!!! where did you find the TBO lip?
79`280ZX
Car: -1981 Datsun 280ZX 2+2 - 1968 Datsun Cedric PL130
A Honda CRX dosent stand a chance against a Powerfull Z32!
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
I dunno, I've seen some insane CRX's....then again my Z would be fun on a road course against one
AZ-ZBum
NickS13 wrote:STUNNING!!! where did you find the TBO lip?
http://www.garymolitor.com/300...f.htm
Return to “300ZX (Z31) Forum”
