my z hesitates at low rpm but it slowly picks up speed 1987 300zx?
Discuss topics related to the VG and VE series engines.
vonc05
Car: 1987 300zx,2004 nissan maxima, 1995 lincoln towncar
my 1987 300zx picks up speed slowly new injectors fuel rail harness all new no mis fire what could it be?
nghtrain88
Car: 1991 Nissan 300ZXTT
all cars make more horsepower at higher rpms
vonc05
It seems like it don't want to pick up speed but it seems to be in a strain then it frees up an takes off!
nghtrain88
how about basic maintenances such as spark plugs/coil packs all firing in spec? dirty air filter? clean throttle bodies? if so have you done a compression test to make sure all cylinders check out? my car seemed to lag at lower rpms as well when i first got it and i soon found out on #6 cylinder the connector was not plugged into the coil pack so it was running on 5 cylinders
AZNiNjARaVeR
Car: TTz32
I had a similiar problem with my 1991 300zx na.It was my injector connections and injectors needed cleaning because they were all corroded and i had my spark plugs changed to NGK's because supposedly the bosh ones suck for the engine LOL
nghtrain88
yeah, stick with NGK plugs. also use some diaelectric grease on the connectors to keep moisture out and ensure good contact.. also use a fuel injector cleaner occasionally
jeramie411
Car: s13
ngk all the way
Return to “VG30 / VE30 Forum”
