S13-in-the-386-407 »
https://forums.nicoclub.com/s13-in-the-386-407-u24927.html
Tue Feb 24, 2009 9:06 pm
Looks like a basic starter kill setup to me, here is how to get it started up again. Since you have removed the starter kill which was the bosch relay and plug you removed. Now directly under the column you see that white plug with 5 thick wires going to it? they should be black with yellow stripe, black with white stripe, blue, white with red stripe and plain black.
IN that mess there should be the other end of the wires that leads up to the key switch, either find that plug and plug it directly back in or hard wires those back together and the car should fire right up with no problems. Let me know if you have anymore questions or need anymore help.
