DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sun Nov 16, 2014 12:41 pm
Welcome to Nico, we do try to be as helpful as possible with our fellow Z-Lovers and sharing our experiences so let's see what we can do!
It sounds like you are off to a great start with sound goals and a solid approach with the repairs you mentioned, however I would not go with a dual electric fan setup with a radiator upgrade, and instead make sure that the stock clutch fan is new and get some of the front airguides that will better seal the air entry area to better flow air over the radiator. You will want to replace the huge stock air box with a cone filter setup (or selin dual intake setup for best setup possible for airflow and correct MAF/ECU operation with mods) for better airflow, and NOT use a large front mounted intercooler (IC) which blocks airflow to the radiator.
I personally will soon be adding upgrade turbos to my Z and will be going with the Z1 upgraded side mount intercoolers, as they are a great deal as a new kit at $495 and do improve performance as well as ensure non-leaking IC's.
Top 10 things to do in my humble opinion...others can add their own take as well!
1. Maintenance- check/clean ALL electrical connectors and replace if necessary, do a boost leak test, 120K timing belt service, clean throttle bodies inside plenum, check/clean injectors/connectors, IACV/connectors, check/replace fuel system parts/hoses/CLAMPS, install fresh correct OEM or better spark plugs, PTU/CAS connectors serviced, cooling/vacuum hoes replaced, coolant service, replace brake fluid/pads, etc.
If an intake plenum removal is in the works (injector service), also consider deleting the unnecessary coolant piping to the throttle bodies under the plenum and any hoses that are part of that delete mod- a well-covered optional but recommended job most Z owners do if/when their plenum is off. If your Z is pre-'94, installing the new style '94+ injectors along with an upgraded fuel rail system is a very good idea.
2. Do some minor mod/deletes- injector voltage mod for '94 and under, brake booster brace added, replace stock airbox with cone filter or selin dual MAF setup, replace boost hardpipes with silicone or metal hardpipes/clamps, move PTU from front of engine to inside front end of car (lower front frame rail or headlight can/nose panel rail most popular choices)
3. Some support upgrades to prepare for more power- service/install upgraded brake system components (larger calipers and rotors, upgraded pads), inspect/service clutch/drivetrain, install upgraded lighter wheels/performance tires. Also a good time to inspect the entire drivetrain and rear subframe and repair ANY issues (trans/engine mounts, shrouds, HICAS system, alignment)
4. Minor performance mods- Upgraded smics, silicone hoses all around, larger diameter IC hardpiping, Ball bearing and/or bigger more responsive turbos, ECU chip upgraded for current mods or a tunable ECU system (Nistune, other) purchased
5. More support mods- upgraded fuel pump, upgraded clutch and clutch system (chromoly pivot, heavy duty fork, shorter (61") SS 1 piece clutch fluid line, check/replace knock sensor and O2's and other hard to test/replace sensors when engine is out
6. Suspension upgrade- coilover system with necessary support pieces installed, upgraded sway bars (NA) and solid subframe bushings installed, optional HICAS delete (TT), Big Brake system (450+ WHP)
7. Looks mods- '99 jspec bumper or favorite other installed, rear diffuser, lip spoilers, front splitter/solid undershroud pieces also available, exterior moldings refreshed/replaced, dash gauge rings, interior leather trim upgrades, seats reupholstered, custom DIN panel, gauge arrangements, stereo, etc.
8. Paint/body refresh
9. Complete interior renovation
10. Complete rebuild and/or restoration
Well, more or less ran out of things at #8, sorry...but basically this all is covered in the "Everything you need to know about your Z32" stickie at the top of the page, in the area quite away down the page titled "Destroying the world in your Z32".
The info there is very accurate and is a good step by step breakdown of the things to do and consider as you modify your Z32.
It seems also that we both have similar goals and tastes for our Z's, check out my own build for many/most of the things listed here that I have done to my Z's over the years.
Good Luck and have a blast!
DCaff300ZX on Sun Nov 16, 2014 1:01 pm, edited 1 time in total.
