My widebody vh/s13 project
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
WYT R1CE
Well I havent really made a post about me, so heres what Im working with...
Before touching anything...
Pulled the manifold to lose all the rats nest of vacuum...
Custom EGR block off plate...
All clean, just had to modify the TB and get rid of the trac control. Ill post more pics tomorrow..
Mocked up the engine today to see what else needed to come off...
There was a bracket in the way that wouldnt let the motor sit all the way in, thats why its sitting so high out. Was caught on the sway bar.
Ordered everything except the exhaust stuff from excessive manufacturing
Mounted it up..
I built my first ever header this weekend wasn't too bad. Varocktoy is helping weld it up, I just tacked it together. Its not too pretty but it'll work for now, the only options for headers are make your own or order mazworx headers for $900. f*** that.
Modified by WYT R1CE at 7:52 PM 3/15/2010
s13lover1
Car: 1993 Nissan 240sx Coupe Base
Thats looking nice. Could you tell me how bad the vibrations are since the mounts are solid because I am actually thinking of getting their kit instead of going custom they say the engine is smooth enough that you don't need isolators Thanks .mine is going to be my DD so I dont want it to be uncomfortable.
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
What are your thoughts on that adapter plate? How thick is it?
kingkilburn
Car: '93 240SX
How is the hood and oil pan clearance?
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Them be some mighty big tubs in the front!
WYT R1CE
The plate is about a 1inch thick, it very nicely made. The mounts sit the engine very low and should clear a hood. I dont have one to test yet though haha. It is made to clear the sway bar but I am running aftermarket knuckles for more angle so I removed it.
I like the whol kit but the mounts are kinda hard to poisiton the engine.
tmorgan4
Car: 2000 Nissan Pathfinder
Does the adapter plate leave any open space around the bottom of the bellhousing and starter? It kind of looks like it would be blocked off. My Mazworx adapter fits perfect but I hate having the bottom open with the amount of dirt my car will see.
1WheelWonder
Car: 1991 Nissan 240sx
Looking good so far!
WYT R1CE
Once I mock up the passenger header tonight and pull the motor back out, Ill take some better pics of it and the mount pics.
WYT R1CE
Driver side done..
Passenger side just needs to be welded up..
Just finished wiring the harnesses. Big thanks to SuperHatch! I skipped all the consult so it was only like 13 wires.
s13lover1
is it to close that you wont be able to make the heater work?
WYT R1CE
It has plenty of room to run the heater. But all of that is removed on my car, the wiring harness is tucked to where the heater core and AC are usually located.
We tried to start the car and got nothing. The fuel pump turns on and most electrical, the starter didnt turn over though. Im going to pull the lower harness and take a look at it.
WYT R1CE
Lower harness was wired wrong. Fixed that and it turns over now.
Now the problem is we are getting no spark. I have a week to get the car out of the garage. The pressure is on.
s13loverdrift1
Car: Nissan 450sx (VH45DE swao)
So you ever get it running and out of the garage? I would like to hear if the solid mounts would be unbearable for a daily drive haha Thanks.
darktalon2gnt
Car: 1992 240sx coupe 1994 q45
hate to gravedig, but I'm curious as to what all you've done to your engine bay other than the swap, I'm building a 240 for track duty and liking the look of what you've done, thanks!
Return to “VH45DE / VK45DE / VK56DE Forum”
