well guys soon enough i should have all mystuff. and i want to get more info then what i already know i really want to get the people on here in on whats going on with my project and any things that people suggest.
first off i have an rb25det engine comeing and i have the gasket sets and everything for it, i was wondering if there is any kind of sealer i need to put on the gaskets when i go to close everything back up.
also i was wondering if there are any tips when it come to putting the engine in i have the mckinney motor mounts and drive shaft.
any suggestions on the wireing, im sending it out to mckinney to get spliced but i will have to put it back together. so any help on that would be great.
power steering pump help is good to, and break line help, any suggestions
also i s15 head light, is it needed to buy the brackes or is there something i can inprovise with and where do they go? i have an S13 by the way.
5 lug conversion, i got the attain fronts but i need help on the rear, can i just get the s14 rear hubs and just screw them right on?
carbon fiber s15 front end conversion (full carbon fiber) any suggestion tips.
putting the Nismo LSD in whats the best way to do it?
getting the old drive shaft off the differential, how whats the best way.
truck, i have a carbon fiber trunk coming should i change the type of hinges used?
exhust, i have a megan 3'' catback what the best way to attach it?
thats about all the major things im doing. in case anyone is wondering i have 17x 9.5 for rear and 17x 8.5 for the front for the wheels, they are 5 zigen GN+ in bronz.
i have new timing belts, boost controler, turbo timer, fuel pump, regulator, injectors (850cc), power FC and commander, Tien Flex with controller, carbon side skirts, carbon r32 wing, bigger radiator, perma cool fans 12'' and 14'', mckinney down pipe, i knows theres a few other things but thats everything off the top of my head.
although i still need to figure out about an oil cooler, what size to get.
all imput is welcome even questions are great. let me know what you think, leave me info anything you want to do.
