does Haynes look at it for free and where is it located?NutriaforBreakfast wrote:My tires gave me a fit till I replaced them
You can also go to Haynes and check the front endparts (ball joints, arms etc)
Ive had sams check it out like 6 times and they said the rims was not bent.jdshift wrote:Bent rims possible?
I have an apointment with them next week on monday to have it checked out.maxhopper97 wrote:Who did your alignment?
I would go to Tony's on Poplar Level Rd and have them check it out.
They said nothing was wrong with the front end. They said it might be the axel, so they said to see if it shimmies when it is neutral, and if it doesn’t it might be a good possibility that it is the axel, but it was still there in neutral.maxhopper97 wrote:They are a good shop, and really not too expensive.
What would be qualified as a professional? I have taken it to the break and aliegnment guys at toney's. Is there anyone in louisville that will look at it for me and tell me what i need.lightsout wrote:-go to Autozone or Pepboys and buy a Haynes Auto Manual-gret under your car and look for anything that doesn't "look right"
-have you had your rotors checked to see if they are warpped?
after looking at it yourself, if you come to the conclusion that you cant figure it out, or cant do the work yourself...take it to a pro
if it was my rotors wouldnt it only shake my stearking when i break only?lightsout wrote:if i am not able to figure out something on my car, i usually go to the dealer and have them do a diagnostics....chances are you're not going to get it checked out for free b/c it would take time for the mechanic to take a look at it...and time means money.
it sounds like you took it to the right place...but did they take off your rotors and check them??!! If they did, but that wasn't the problem, take your car to your nearest dealer.
LMK if you two are going to hook up. I have a garage, ramps and floor jack available if neededmaxhopper97 wrote:Shoot me an email before this weekend, and we'll figure out a time and such.
I know right.NutriaforBreakfast wrote:The dealership would have charged $800 for all that
Get that man a steak dinner!
