BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Tue Jun 08, 2004 1:22 pm
put 10mm spacer then. if you're staying 4 lug and want easy install, you're just going to have to deal with spacers. Get something with a higher offset and use spacers to tune it a little bit. Push them out to where you like it and it doesn't rub.
And if people are running 18x9.5 fronts.. you should be able to fit 17x8's.
