email me and we can talk about iteh? wrote:Did some testing this morning:14psi, 3rd gear, 102% duty cycle, 7200 rpm (soft cut), 11.5AFR, no change knock voltage.
t3/t4 50 trim, internal wastegate.
370 cc's definetly not safe at 14psi with a t3/t4.
Hey Krayton - can I see your ignition map?
My car weighed 2650 and I was on 245 rwhp when I ran a 13.3 @ 110 back to back to back. I was just curious why his trap speed wasn't higher.DriftingisLame wrote:Jon thats almost 500lbs more than your car, and by the looks of it bald tires and/or all seasons.
Sounds right to me. Traction and a launch would help a lot =P
Well I figured you had traction problems because I was hitting 2.3 60' also. No doubt you will be mid to high 12's with even a 2.0 60'.krayton wrote:i had some major traction issues. i didnt hook up till 3rd gear. just kept pedaling all the way down the track on 1st and 2nd.
these are brand new 275 bfgs i put on for the strip.
with 110trap speed i should be in the mid to high 12s.
friend with me ran 12.7 at 111 w/ 2.1 60ft. he was having some slight traction issues too.
AHHHH! bad! no no no no!eh? wrote:Did some testing this morning:14psi, 3rd gear, 102% duty cycle, 7200 rpm (soft cut), 11.5AFR, no change knock voltage.
holy frig? is that in lbs? lolHolyShiznit wrote:
My car weighed 6550 and I was on 245 rwhp when I ran a 13.3 @ 110 back to back to back. I was just curious why his trap speed wasn't higher.
No I weighed 2650 at that time. I meant 2650. I just suck at the intarnet.DriftingisLame wrote:He means 2550
