OK so I have not posted in like a good two months because of random crap going on in my life but here we go. I have had my 240 going on 8 months now and It has made me very happy, that is until something goes wrong on it and I have to fix it lol. So about oh 4 months ago the water pump pulley on my SOHC decided to snap off while I was driving which strangely didn't cause my car to over heat on the half mile drive home. So I replace it and every thing seems fine but then it starts to get hot like it wants to overheat after I put the new pump in so I test the thermo and it failed so I got a new one and put it in. Still it over heated so I flush it (multiple times) and see if that does it, nope. At this point I am thinking I blew a head gasket so I do a compression test on it and one of the cylinders in low on compression but not enough for it to be a head gasket. Well I pop the valve cover off and check the torque on the head bolts, turns out the exhaust side was under torqued so I torque them down to spec (I know they are stretch bolts and they will lose torque but I needed the car fixed). OK so this seems to work but them the problems starts again but slower so I guess it was still leaking. Well after that i parked it for about oh a month and a half and then two weeks ago I gathered enough money to get it fixed and what not by my mechanic. He does some tests then tells me the head is fine but the cooling system (radiator, fan clutch, Etc) besides the pump and thermo were either clogged (radiator) or broken. I have him replace/fix them and he calls for me to come get the car because it runs "fine" now.
I go and pick up the car (1990 240sx sohc automatic
) and start to drive it home and it seemed fine but I had a bad feeling it my gut that it wasn't fixed. As i am driving it starts to heat up a little so I turn off the A/C but it still climbs so I call him up and say it is doing it again and turn around (after driving about a half hour) and go back. On my way back it gets hotter and hotter so I blast the heater in attempts to cool it. By the time I got there it was just about to over heat so I park it and he checks it out over the next day and calls me saying he F*cked up, and that it did need a head job and a new gasket *sigh*. Ok that's fine I say I just want my car back so fix it (this is after already paying $380 for the previous stuff). Now normally I would be doing my own car work but I have school (UTI) from 1:00pm till 7:00pm and cant really get anything done. So today (07/29/10) I call him and ask what is up and of course nothing is easy because he tells me that the machinist came to pick up my head for redoing and did some tests on my block to make sure it was ok..... well it had a crack in cylinder 2 going threw to the water jacket.
OK now I have only one option..... swap the b*tch and move on. lol my course of action is this; pick up a Dohc motor and 5spd trans and other required parts for swap (slave cylinder,clutch pedal, Ecu and harness, etc.), an exedy clutch, Nismo motor mounts, K&N intake, shift boot, Nismo shift knob, and possibly a Flowmaster cat back exhaust to round it all off. All of which will cost me about $1300 to $1800 with out labor and with him just installing the motor set and nothing else ( I can do all the normal sh*t) it will be $700 more on top of that. So ya sorry for the long a** post but I had to get it off my chest some were lol. But ya my wallet as the title says is dead. Now that amount may not seem like a lot to some but I am 17 and in college with no job, so it is a lot to me. There will be more to come when I get stuff together and there will be pics.
