between $300 to $350.White Comet wrote:not really a waste, it depends on the price and its kinda hit or miss
First of all a transaxle is only on FWD and AWD vehicles, your 240 just has a transmission and rear differential.elpiar wrote:I'm in ohio and this morning we got our first snow shower.
I got J30 VLSD diff. with kumho ecsta asx tires
My tail always drift to the right when I lose traction. It seems to me that the right side spins faster than the left.
I am also suspicious cause when I bought the car last year the right rear tire is all bald while the rest is still at 50%.
Is this inherent to VLSD or something is wrong with my transaxle?
lol, my mr2 has a transaxle and it's RWD!Chukidori wrote:First of all a transaxle is only on FWD and AWD vehicles
Exactly what I was about to say. +1 man.Invalid Zero wrote:It's most likely because of the crown of the road. Roads aren't made flat, they have a slight crown to evacuate water to the gutter/ditch.
Pull onto the wrong side of the road and try spinning em.
Well i'm glad your avatar text says you don't own a 240 yet, because you're wrong. The engine/trans spin clockwise when looking @ the crank pulley from the front of the car. Thus the rotational force would want to spin the car clockwise also, giving more traction to the drivers side rear wheel.240sx_Guy wrote:the drive shaft is spinning towards the pass sidethe torque from your drive shaft causes right wheel to burn or for the wheel to get better traction
or something like that
Sorry to keep posting but I guess I can't add quotes while editing. You're almost right man. I've got a helical and did much research on this. Helicals are commonly used in 4wd or off-roading systems. In the owners manual for hummers, it tells the owner that if they get stuck even if one wheel is on the ground and another is completely up off the ground or on ice (meaning it has no resistance to torque) the other wheel won't spin and you'll have an open diff affect. HOWEVER, if you apply the brakes in this situation the other wheel will have resistance and your torsion differential will transfer the torque to the wheel with more traction.redtop91 wrote:I'd say Helical because if one wheel is completely without traction, torque will be immediately transferred to the wheel with traction. Save you a few seconds of revving LOL.
i thought the ring gear was on the differential case, not one of the axles, and power gets to the axles through the side gears in the case.elpiar wrote:I was talking to my Mechanical engineering prof today and he explained to me briefly:
In most RWD cars, The engine is upset clockwise (assume front view of the car) since the crank shaft rotates counter-clockwise and therefore the whole body of the car dynamics affects the traction each wheel has. As a result, the rear right has less traction due to having less normal force compared to the rear left. This is inherent to longitudinal-engine-RWD cars.
In the case of open diff, this is mainly due to the fact that the ring gear in the diff is on the rear left axle, therefore the power goes to the rear right first and if there is no LSD there is no way to transfer the torque to the left side. Open diff always puts out the same torque for both wheels.
normal force is the same as what you call downward force. So we're talking about the same thing. Everything you write is exactly correct.Didderson wrote:^ Bah i didnt read that yet. I'll have to think about this a lot lol. I didnt think about the normal force man. now i'm confused. only one way to find out. get a muscle car w/ the clockwise rotating shaft and see which way it rocks to.
If you do google on "torsen differential" you'll get many links with good explanation. a torsen will multiply whatever torque you have on the slipping wheel with the bias ratio to the other side. So if you got only 50 ft-lb on the slipping tire, and the bias ratio is 4, then the other side will get 200 ft-lb at this instant.Didderson wrote:
Hope that explains it. There's threads on nico that say the same thing. Helicals are great as long as both wheels are on the ground
Yea i learn a lot from his explanation. Also, everytime I ask a question I keep on looking around for info while waiting for replies. When i found additional info, I share it here. That's the whole point of forum, right?homeslicej2 wrote:Glad you got your mech. eng. prof to tell you about powertransfer. You seem to know more than you let on as well You testing us?
good way to use the forum, better than some of the post whores around hereelpiar wrote:
no i'm not testing, seriously
same here, and that made me wondering if the Vlsd still works...jtothed wrote:Hey I'm from Canada... so yeah there's snow. My almost completely stock S13 w/ OEM VSLD kicks to the right in the snow when losing traction, all over a flat parking lot.
Diff fluid is good, VLSD deff. works as it should.... I checked
