I've been getting countless emails and people telling me I need to update my project. I had good intentions of documenting the whole thing, but after working on it for almost year I got a little burnt out and starting documenting less and less. All I've got left is pictures, so here's a few from the hundreds that I've gotten over the entire project.
Here's how it started...hydrolocked VG33. The VH45 won't be THAT much more work...right?
Picked up a VH45 locally that had low oil pressure from worn bearings. Entire engine got rebuilt....bored .040" over (It's now a 4.6 liter), rebuilt heads due to leaking valves (one was slightly bent), and all sorts of other parts.
Updated guides since the older ones didn't have a metal backing and were prone to cracking and ruining the engine.
Heads are on, new knock sensors installed, starting the cooling system.
New injectors from the later model VH45s. The older ones are more prone to failing than the new ones.
Almost complete
First test fit. It's going to be close.
Started the engine mounts...all I had was some 1/4" wall DOM.
Engine is finally in.
Started on the steering. Decided to go full-hydro since I already had most of the parts and the oil filter housing on the VH interfered with the stock steering box. Cutting the rack and pinion mount off with a grinder was horrible.
Steering valve mount
Onto the wiring. At this point all of wiring is labeled but needed to be spliced into the body harness.
New DXD stage 2 clutch. Good for 480 ft-lbs of torque. I will recommend these clutches to ANYONE. Good prices and it drives awesome.
Transmission needs installed. After sending half my transmission to Florida for machining I get it back and it won't work. Send another transmission to Florida and get it back. I now have a "hybrid" transmission that uses the front half off a NA Z32 300zx since the starter is now mounted on the side of the transmission instead of the front.
More pictures on the way.
