BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Wed Jun 20, 2007 4:26 pm
There is a much better theft deterrent that can be built with some 1/2" steel tubing and a tank of propane. Just drill small holes lengthwise in the tubes, one tube for each side (long enough to fit between each wheel well). As the door is opened, it'll trigger an electronic ignitor that will send flames shooting out from under the rocker panels. If you want, you can also install an electic fence charger that will electrocute anyone who touches the body (but don't expect any of the cars' electronics to survive).
