proxim2020 »
https://forums.nicoclub.com/proxim2020-u47252.html
Wed Nov 01, 2006 8:30 am
This is pretty common with all types of cars with cloth seats across the board. You can build up a charge just from driving and making slight movements. It's the same effect as rubbing a balloon on your hair to make it stand up. You will start to see it happen when you move to the cooler drier months, which is right around now for you since you're up in NY. During the winter time, I get shocked constantly getting out of my truck, but not during summer months. Have you been getting shocked on rainy day? Static electricity doesn't conduct well through humid air. If you're still getting shocked, you may have a more serious problem.
When you get out, grasp the metal part of your key. If you look in your door jamb there should be a hook that your door catches to close. Touch the end of the key here and you will discharge through the tip of the key. If it's strong enough, you may be able to see a little blue spark. And no more pain .
One more thing, being shocked works to your benefit when going to gas stations. PLEASE make sure you touch an unpainted surface every time before grabbing the pump. You can charge back up from just going back to your car to sit for a second. If you don't, you can discharge through the tip of the pump when it touches you filler neck. That can cause one of those big fires you see on CNN every winter.
