Jrscherer wrote:Hopefully wasn't something too bad, I just have to say, if 30 is cold for you, what would you do with the temps that wisconsin has had of -10 to -20 and that's without windchill
I agree. I'm just in Iowa, and it's been under 5F in hte morning all week. The car starts just fine. Just a little extra delay turning over due to the expected weaker battery, and thicker fluids. The transmission fluid is so heavy, that the RPM's drop 100 RPM's when you release the clutch in neutral (transmission starts spinning)
Coldest start in this car is -5F. I once had a '91 Toyota Tercel that started up just fine at -25F one very cold morning in Michigan when I was in High School.
More than likely it's related to a sensor problem. Bad gas (usually caused by moisture) would be more likely to cause a drop in power and misfiring, but not the bogging your expereincing.
