Thanks, heres pics of it
Hey I tried your screwdriver method in tapping the manifold out and it's really sealed on there. Is it possible to unbolt the top manifold from the head and leave the manifold in, and then extract the head?Ken@PTUNING wrote:Take a screwdriver or chisel and tap with a hammer where the flanges mate. Once it starts to separate, you should be able to pry them apart.
I personally just remove the manifold completely from the head instead as one piece. It makes maneuvering the head over head studs easier. That and some machine shops will not resurface the head with the intake manifold still attached.
So I should remove the bottom of the manifold and take the head out with the entire manifold attached? And i still don't know how to dis-attach the throttle cable. Pics of the bolts would be help.Ken@PTUNING wrote:I wouldn't. Of the 10 fasteners that secure the manifold to the head, 8 are bolts and 2 are studs. Besides, at that point you've practically removed the manifold completely.
Alright so I just had some free time and I've released the throttle cable. So I do remove the manifold from the head, like the top bolts and stuff? And how many bottom bolts are there? Also can I just leave the fuel rail on the manifold?Ken@PTUNING wrote:The throttle is held on by two jam nuts. Loosen them and slide it out of the way. Then there is a T bolt at the end of the cable. Rotate the throttle, lift/rotate the cable away from the pulley and you should see a grove that you can slide the T sideways out.
Remove the entire manifold from the head.
